y20dth original bin/ori
Results 1 to 4 of 4
    Jan 2019
    24
    Default y20dth original bin/ori
    First of all, what are the differences between ori and bin extension ? I will buy kess v2 Eu clone( searching on internet I found that kess v2 can write files to ecu via OBD directly) or should I go for fg galleto or mpps v18 ? Some persons said that mpps v18 can read also via obd but I doubt about that.
    This is my HW and SW, If someone has a original file with the same proprieties as mine, If tunning file is bad, I will put original back to safety .
    Also I am interested in one +25hp for my old lady with optimized glow plugs start fix--> stage 1 If some has it with my SW and HW
    Danke
    a500tut's Avatar
    Jun 2017
    Belarus
    16
    Quote Originally Posted by Andr33iy98 View Post
    Danke
    Thanks and rep.
    If I helped you, click thanks and reputation
  3. The Following User Says Thank You to a500tut For This Useful Post:
    Andr33iy98 (30th July, 2020)
    Jan 2019
    24
    It is safe 100% this file ? Is my original file then
    ? If something goes wrong I can upload this file to get back to normal ?
    Thanks a lot
    But what about tunning map ?
    a500tut's Avatar
    Jun 2017
    Belarus
    16
    Yes, this is the original file and you can always write it back, even if something goes wrong. On the issue of tuning the file, write me a personal message.
