Results 1 to 15 of 21
    May 2014
    Default cd 30 mp3 with aux not divorced but i have dump
    Hi, I bought a cd 30 mp3 with aux from the scrapyard, then I went to the dealer that sold that car back in 2007 and got the security code for it but programming fails with this (0918), can someone find the code in this dump, or put the whole radio in "delivery mode" ?
    Bulgaria
    code in this dump is 7686....
    Here is dump in "delivery mode"................
  3. The Following 3 Users Say Thank You to bogege For This Useful Post:
    budata (30th July, 2020), masterskay62 (30th July, 2020), smoggy (30th July, 2020)
    May 2014
    That worked like a charm!! no safe messages now. thanks!
    May 2014
    Actually it did not work... when I wrote the dump into eeprom I got an error and now it says "program radio" in the car, Ive now tried reprogramming eeprom with the original dump and Ive tried with the unregistered one, but I get an error when programming and then it says "program radio" in the car..
    I use XGPRO v10.13
    I can see after programming that the dump looks the same when I read it but im guessing that the error in programming renders it useless in the car, hence "program radio" message..
    May 2014
    Default xgpro
    Here is program I use
    budata's Avatar
    Feb 2018
    Bulgaria
  8. The Following User Says Thank You to budata For This Useful Post:
    bogege (30th July, 2020)
  9. #7
    May 2014
    Still get error when writing.. 🤔
  10. #8
    WALES
    Quote Originally Posted by perabuss View Post
    Still get error when writing.. 樂
    Clean the chip and program again... the programmer is your problem
    wbr
  11. #9
    May 2014
    Now I know why it worked but then suddenly stopped working 😅 I have no idea how I made that happen..
    I have a board from a same cd 30 mp3 which does not have aux, dont know if I can do something with that..
  12. #10
    WALES
    Now I know why it worked but then suddenly stopped working  I have no idea how I made that happen..
    Just clean the chip with white spirit and write again....
    wbr
  13. #11
    May 2014
    Yes, but look at picture attached, ive totally smothered the chip beneath.. will need to get a new cd 30 with aux if I cant use the ones I have somehow
  14. #12
    May 2014
    Default New unit
    Hi, I have new unit, can someone extract security code and virginize dump
  15. #13
    budata's Avatar
    Feb 2018
    Bulgaria
    Poor reading.....
  16. #14
    May 2014
    I get inconsistent readings.. Cleaned the pins with white spirit and checked all connections.. attached new reading
  17. #15
    budata's Avatar
    Feb 2018
    Bulgaria
    You're doing something wrong again ... change the tool.....
