Results 1 to 5 of 5
    Jan 2018
    shaftesbury,Dorset,UK
    Default Seat Leon ARL PD150 Tuning 0281011193 038906019KG
    Hello does anyone have a good tune for this engine? best max power possible??
    thanks guys will be thanked and repped!
    this file I have pulled from car is not good tuning and I dont know where to start without original, when using donor file it not work properly with abs system as from older vehicle..
    has had straight through exhaust and egr delete done
    thanks again
    dominik.m's Avatar
    Jun 2009
    POLAND
    It's best to take a picture from the ECU sticker. Perhaps someone wrote the wrong software. Maybe then someone will help you sooner. By the way: without mechanical modification with software alone, you will not reach 200HP.
    Jan 2018
    038906019KG SG5342 is software id and 0281011193 is bosch partnumber Sorry, also it has had egr delete straight through exhaust.
    moky's Avatar
    Behind you
    here your original file and safe tested tuned file 200hp 420nm
    pass after thx and rep
  5. The Following 2 Users Say Thank You to moky For This Useful Post:
    kennyash1 (29th July, 2020), kismurmi (2nd September, 2022)
    Oct 2018
    Quote Originally Posted by kennyash1 View Post
    thanks again
    here you have.. send me pm for pass
