Results 1 to 11 of 11
    Aug 2019
    Romania
    Default Audi 8D0907557T IMMO OFF
    Hello can anyone help me this immo off .
    Car is Audi A4 1997 8D0 907 557T Bosch 0261 204 185 the cip is B58258 = 24C02
    Press Thanks Button and Reput if i helped !
    here you have tested solution !!!
    pass pm after thank and rep!!!!
  3. The Following User Says Thank You to sabian For This Useful Post:
    BadeaCristian (1st August, 2020)
    Aug 2019
    Romania
    Quote Originally Posted by sabian View Post
    and the password?
    Aug 2019
    Romania
    not working
    did you lift pin 7 and put to pin 8 after write? did remouve immobox under steering wheel? i tested this file with a lott of cars never problem!!!
    tazz75's Avatar
    Nov 2018
    Hy..here..pass in pm try and report
    Aug 2019
    Romania
    the car doens't have immo box...i did the step but it works until i remove the battery
    Aug 2019
    Romania
    can you extract pin and try to learn it with vcds?
  10. #9
    May 2020
    Don't go immo off. Try SKC 3283 and report back.
  11. #10
    Aug 2019
    Romania
    Quote Originally Posted by Makubika View Post
    not working (different version of IMMO beetween donor car and curent car)
    I replace the eeprom with 24c02WP and now it's working.
  12. #11
    May 2020
    tot557545@gmail.com
  13. The Following 3 Users Say Thank You to ecuprogramer For This Useful Post:
    autodigital (17th August, 2020), BadeaCristian (20th October, 2020), Przemo4444 (16th June, 2021)
