pcr 2.1 1.6CR Golf Help please!
Results 1 to 5 of 5
    91
    Default pcr 2.1 1.6CR Golf Help please!
    Hi!
    I always get the error code P2279.
    There are no leaks.
    Swirl off might solve it, maybe.
    Portugal
    88
    Can you describe the error ?
    91
    This fault code P2279
    7338 - Leak in Air Intake System
    P2279 00 [167] - -
    Portugal
    88
    hecks the intercooler tube next to the turbo if it is not damaged (torn)
    Check if you have any damaged vacuum capsules such as E: G: R which are sometimes damaged.
  5. The Following User Says Thank You to rui For This Useful Post:
    hamitie (2nd August, 2020)
    35
    Try another MAP sensor. Sometimes solve this issue
    BR
    Ivar
  7. The Following User Says Thank You to ivarf For This Useful Post:
