Results 1 to 8 of 8
Thread: Suzuki Vitara
    Jan 2018
    Cuba
    Default Suzuki Vitara
    immo 33970-70E03 x24c01
    ecu is33920-70ER 24c04
    immo lamb is blinking
    key data and dumps are attached
    Please check and if need sync them.
    Everything happened after the battery ran out.
    Regards.
    Meat-Head's Avatar
    Very easy job, but not right now as im in the bath
    if you search on here you will find solutions
    simply write the key data as in in the dump of immo
    you CAN include an entire list of obscenities to the engine ecu
    Your doing REALLY well if your from cuba
    soldering iron, key reader, eeprom reader, computer, internet
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    Try this dump.
    Good luck
  4. The Following User Says Thank You to bram380 For This Useful Post:
    Meat-Head (2nd August, 2020)
    Jan 2018
    Cuba
    Hi. Same error. P1621. Immobilizer communication line error.
    Thanks.
  6. #5
    Meat-Head's Avatar
    If bram380 says it will work, take his word for it
    a) bad soldering b) immobox corrupt
    remove immobox and see if can immo off instead. But check fuses first
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    bram380 (3rd August, 2020)
  8. #6
    bram380's Avatar
    Aug 2009
    Quote Originally Posted by rolovalero View Post
    Thanks.
    DTC P1621 please check line beetwen immo and ecu.
    https://zinref.ru/avtomobili/Suzuki/...h_2007/536.htm
  9. The Following User Says Thank You to bram380 For This Useful Post:
    Meat-Head (3rd August, 2020)
  10. #7
    Jan 2018
    Cuba
    If I upload another bin (from other Vitara) to immo eeprom, then the error is 1623 (unregister transponder). Of course, my key is not registered, but change te error, why?
    Could be corrupt my immo bin?
    Please can you check tne immo dump.(Its on my first post).
    Thanks.
  11. #8
    Jan 2018
    Cuba
    hello.
    With these immo and ecu dump, the error is p1623, unregistered transponder.
    thx.
