Results 1 to 9 of 9
    Feb 2013
    North of the South, Venezuela, self-exiled in D.R.
    Default Passat CC Med17.5.2 Chk error P160A, Immo Active after cloning, please help!!
    I tried to clone an ecu med17.5.2 without success. Can someone please help me correct the checksum error.
    PAssat CC. 2010 2.0 ECU HW 06J907309B
    Here is the Ktag reading of the old Ecu and the new Ecu.
    Thank you so much for your help
    ASCM's Avatar
    Oct 2018
    Which version of ktag u used ?
    Sent from my SM-J415F using Tapatalk
    Sep 2015
    Hungary
    Here you have Bro....Please send report....
    If I help, please use THX+REP button...
  4. The Following User Says Thank You to Stig33 For This Useful Post:
    aquilesy (2nd August, 2020)
    Feb 2013
    Quote Originally Posted by Stig33 View Post
    Thanks bro, what tool you recommend for match this med17 ecus?
    will test it
    Feb 2013
    Brother you send same file, without modifications, same error, verify with hex editor
    Feb 2013
    please, somebody to help me to math immo at this ECU.
    Sep 2015
    Hungary
    Sorry Mate... Previously file is wrong, here is the correct !
    May 2020
    tot557545@gmail.com
  10. The Following User Says Thank You to ecuprogramer For This Useful Post:
    aquilesy (6th August, 2020)
  11. #9
    Feb 2013
    Thanks to STIG33 and ECUPROGRAMMER for help me. please password for extract.
    the stig33 solution worked for me, the car started, but the new ecu seems to be damaged, I update software but dtc errors.
    I will have to buy another ecu again,
    I hope you help me to make the pairing again. Thank you
