Try code 2671 or 1762......i am not sure is good......
SDO (3rd August, 2020)
this unit is F250 FL
try code 2421
If I help you, just press Thanks and Reputation
budata (3rd August, 2020), masterskay62 (3rd August, 2020), nelutzul40 (3rd August, 2020), SDO (3rd August, 2020)
I will try n report, thankyou
The pincode worked great. Thanks a lot, sorry for the late reply, only just got to plug in the radio.
can you please decode 2 more of the same radios. Fit Ducati F 250 FL, 24c32 dumps attached.
steve
Albert G (11th August, 2020), arık (11th August, 2020), Decode Ghost (11th August, 2020), irfa (11th August, 2020), SDO (12th August, 2020)
Can I please have these 2 files decoded for the same radio ?
steve
Albert G (1st September, 2020), catalinosonesti (1st September, 2020), golo (1st September, 2020), SDO (2nd September, 2020)
Hi can i please have the code from thhis 24c32 dump out of a delphi f250 FL. thanks
Crasftsman (15th November, 2021), Decode Ghost (15th November, 2021), masterskay62 (15th November, 2021), SDO (15th November, 2021), smoggy (15th November, 2021)
hi, can i pleasse have code for this file as well, F250 FL 24c32. Thanks
Code: 6353
Decode Ghost (2nd December, 2021), masterskay62 (2nd December, 2021), SDO (3rd December, 2021)
Thankyou for your help. I had a query, I have a lot of these radios, do you think if I start loading dumps with known pin codes, it will work ? Or could it clash with other flashes on the board
Hi , ccan i please have code for this radio , fiat ducato fl250 24c32
Decode Ghost (12th August, 2022), SDO (14th September, 2022), shooting (12th August, 2022)
