Results 1 to 1 of 1
    Default opel omega edc15 turbo control
    Hello there,
    Im dealing with damaged sw from opel omega ecu. The car comes originaly with BMW engine m57d25. This was swaped for M57D30 from BMW and original ecu "tuned" to work with 3.0 engine. Anyway there was some electrical fail with short circuit and from that time turbo control doesnt work. Ecu was changed, software cloned but problem persist. Ecu is ok as the same ecu with stock software works and turbo control is ok. After flashing moded software is will stop working again. Also it was working in this moded state before shorting to ground appears.
    Will be anybody so kind and check the file, where could be the problem?
    Thank you
