    Mar 2019
    Earth
    Default E90 headlamp washers coding NCS EXPERT
    Hi guys
    working on a 2006 bmw 320d e90 .The customer changed his headlamps with xenon and brought the washers system.I already made the wiring diagram acording to TIS.
    Now i want to code them with ncs expert.can someone take me thru the procedure?
    Jan 2018
    I have done this before, but long time ago. Do you know how to code with ncs? And you need only option code, or you never did something like that?
    You need to add option to fa and code control units with psw.trc. if I have time tomorrow, I will try to find option code. But a can't promise, cause have a lot of work. If you never added function with ncs, I can't guide you through all process.
    Отправлено с моего SM-N975F через Tapatalk
    Mar 2019
    Earth
    I know how to use ncs expert I ve coded before. I just need the code that needs to be added in VO and the line that needs to be modified in fsw
    Jan 2018
    You should make a copy of every module psw you code for secure reasons.
    Options possible are
    S500A HEADL.WASHER SYSTEM/INTENSIVE CLEANING
    S502A HEADLIGHT CLEANING SYSTEM.
    I don't remember how to check what modules should be coded. Really long time ago did BMWs
    Code with this option cas (FA_write), then read psw code and make coding for needed modules.
    I don't advice to code all car, because you can erase options added manually with another guy.
    Jan 2018
    As I remember, control units code list could be found in ncs dummy, but I don't find how to do it now. And I am going home already.
    Jan 2018
    Oh, didn't noticed that you want xenon option too..
    Thought you need only washers.
    Google bmw fa code list e90 and first link is what you need.
