Results 1 to 7 of 7
    Default VW JETTA PLEASE TUNNING FILE
    1037375199 1.9 BKC PLEASE TUNNING MORE POWER (STAGE 2). THANKS (now is not tunning, removed egr and hot start)
    anyone please?
    please its urgently
    aby23's Avatar
    Mar 2019
    Romania
    Your Tuning File is here, please press thanks and reputation button for your password
    Best Regards
  5. The Following 2 Users Say Thank You to aby23 For This Useful Post:
    goranradovicpg (4th August, 2020), Ricardo Murta (14th November, 2020)
    my friend always see error P0401 and I cant remove
    Jun 2020
    Quote Originally Posted by goranradovicpg View Post
    Hello mate , i dont know what file you put in your car but...
    What causes the P0401 code?
    The EGR valve does not open fully due to a low vacuum opening the valve from the EGR control solenoid or the EGR is unable to hold the vacuum.
    The EGR temperature sensor does not register enough temperature change to open the EGR valve.
    The EGR passages are partially blocked and not allowing sufficient exhaust gas flow into the intake manifold.
    Oct 2020
    san luis, argentina
    algun mapas xa mas torque en Jetta 2.5L ME17.5.6 del 2015
