Results 1 to 4 of 4
    rekmwrite's Avatar
    Oct 2019
    Default need clean eeprom for temic 6900727
    hello, i need clean dump for temic 65.77-6900727
    2000 bmw 540i
    vin: WBADN6349YGM68071
    production date: 03/2000
    the donor car that this module came from is:
    2000 bmw 540i
    vin: WBADN634XYGM68709
    production date: 05/2000
    here is what i read from donor module:
    thank you!
    Mar 2017
    جیتھے دل کرے
    Find attached clear file. cleared with Airbag Universal repair 2011
  3. The Following User Says Thank You to Aliazadar For This Useful Post:
    rekmwrite (5th August, 2020)
    rekmwrite's Avatar
    Oct 2019
    Quote Originally Posted by Aliazadar View Post
    File worked , but when I try to code it, my scanner says “unable to code because this module is coded for another vehicle with different chassis number”
    Is there a way to “renew” or make “Virgin” this file ?
    What exactly did the universal repair software clear ? I see that it FF the first 32 bytes , and then several more down the line.
    Excuse me ignorance, I’m still learning .
    rekmwrite's Avatar
    Oct 2019
    Successful reprogram and coding with bmw ista/p and ICOM . I suppose we’re supposed to read the old if you can and write to new with crash/faults cleared and fixed assuming replacement has no hardware faults
