Results 1 to 10 of 10
    Sep 2018
    USA
    Default 2017 Rav4 Srs on after miles job
    Any ideas on why the SRS malfunction has come on after doing a mile job? Everything else is good. Took battery off and cleaned with launch scan tool, but srs still comes back. Maybe a higher grade scanner can clear it, or something with the coding? Used sf tool, usually no problems for this car. Thanks.
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Well what is the code for srs? Have you saved original file? Try putting original file back.
    Try the easy things first, and backtrack what you did. Not so hard.
  3. The Following User Says Thank You to ateyourv8 For This Useful Post:
    MileageAudit5 (4th August, 2020)
    Apr 2018
    EU
    Did you put the car on ignition without the dashboard installed?
    If i helped you with your problem, please press the Thanks button.
    Ask your questions in the forum, no response on private messages.
  5. The Following User Says Thank You to Diagcar1 For This Useful Post:
  6. #4
    Sep 2018
    USA
    Quote Originally Posted by ateyourv8 View Post
    I do have the original file saved. That is an option. According to my scanner the 2 airbag codes that are not clearing are B1650 “Occupant classification system malfunction” and B1794 “Occupant classification ECU battery positive line open” thoughts? I’ll probably end up writing original file back but hopefully I can avoid that option.
    Sep 2018
    USA
    Quote Originally Posted by Diagcar1 View Post
    I do not think I did turn car ignition on without dashboard installed. Although, I may have unlocked it since key was in my pocket. If I did maybe it’s why srs malfunction comes on screen?
  8. #6
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Check fuse for OPDS and calibrate passenger seat.
  9. The Following User Says Thank You to ateyourv8 For This Useful Post:
    MileageAudit5 (6th August, 2020)
  10. #7
    Sep 2018
    USA
    Checked fuses, all are good. Wrote original file back to the car and same srs codes are still there. Tried clearing with snap on scanner and codes turn off then come right back. Is calibrating passenger seat still a potential solution? Not sure how to do this but I’ll look around.
    Would resetting the srs module do anything since no accidents have occurred?
  11. #8
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Yes, go to opds menu, should be seperate from srs menu. If you have no communication, start checking wires.
  12. The Following User Says Thank You to ateyourv8 For This Useful Post:
  13. #9
    Sep 2018
    USA
    Great, will try today and post update. Thanks for the info
  14. #10
    lwood's Avatar
    city of angels
    you need to calibrate passenger seat.
    miles job, did not cause this problem..
    DON'T JUST SAY PRESS IT.....
