Results 1 to 15 of 16
    Default Mercedes w205 Delphi engine ECU CRD3 Clone or Virgin
    I have here Mercedes w205 with faulty engine ECU.
    Processor inside is faulty. If I heat up ECU the engine starts fine. After cool down engine donīt start, ECU does not respond.
    ECU Delphi CRD3PLUS.A0 A6519004500 A6519014000
    To solve the problem I bought an used ECU with same part numbers.
    Inside the ECU I have TC1797 and external eeprom.
    With Boot mode on PCMFlash I am able to read and write Flash and eeprom.
    I read files on ORI ecu and write files on Used ECU. However engine donīt start.
    Donīt have error codes, however I can see engine ECU has no Start authorization.
    This processor TC1797 has OTP area that is not possible to write. So, maybe this is my problem...
    Attached I send you flash + eeprom files for ORI and Used ECU. Also the flash file on Used ECU after writing ORI file, just to confirm it could not write OTP area.
    Any idea to solve the problem ?
    Anyone has a virgin file ? How to program after Virgin ECU ? I read we could program with Xentry, but needs online or no ?
    Many thanks for your help. Really donīt know what to do now.
    metallo's Avatar
    Jun 2018
    Italy
    if i'm not wrong you can code back these used ecus with avdi by obd and connecting directly over the engine can line, and you can change the vin inside. i did this on an a180 not long ago. maybe you can do the same with other instruments!!!
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by metallo View Post
    abd that all you have done on FBS4..?
    Quote Originally Posted by aqua_life View Post
    this crd3 you can clone even flash by obd and eeprom by boot/bench/soldering...
    try to write flash in boot and disable checksum correction in pcm sw...
    no otp on this kind of ecu, as I wrote even by obd you can read full flash....
  4. The Following User Says Thank You to figani For This Useful Post:
    aqua_life (4th August, 2020)
    metallo's Avatar
    Jun 2018
    Italy
    Quote Originally Posted by figani View Post
    Yes i've done it on fbs4 with the online function but not on w205, there should also be a video on youtube for fbs4 renew
    figani's Avatar
    Feb 2018
    now you are writing only about Virgin...
    in your first post you wrote much more...
    after you virgin it...
    how further with 4FBS....?
  7. The Following User Says Thank You to figani For This Useful Post:
  8. #6
    figani, Thanks for your help.
    In PCMFlash I have option to write complete Flash areas.
    This way it worked fine.
    Thanks again !!
  9. #7
    metallo's Avatar
    Jun 2018
    Italy
    You can use sae j2534 interface with original online sw to code ecu
  10. #8
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Which SW us this?
  11. #9
    figani's Avatar
    Feb 2018
    Quote Originally Posted by teerak2uk View Post
    Which SW us this?
    Abra Kadabra simsala bim software maybe...
    Mercedes online account with higher permission...
  12. #10
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Difficult to find I think
  13. #11
    UK
    I know this is an old thread, but really hope you can help pls. Do you have the connections using pcmflash. I'm in exactly the same situation as you were. I've just purchased module 53 but struggling to get a connection pdf
    Many thanks
    if this post was usefull
    please press
    the thanks button
  14. #12
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by looly View Post
    Many thanks
    https://mega.nz/file/wQMn0YTa#iebtp3...UuWdZtB_6BSx2w
  15. The Following 3 Users Say Thank You to teerak2uk For This Useful Post:
    dule14786 (11th March, 2022), jenya (20th January, 2023), looly (11th February, 2022)
  16. #13
    UK
    I notice in that diagram there are 2 can L pins, is this correct or should it be 1 high & 1 low? Also, I have the breakout adapter from Chiptuning shop but it does not have a cnf1 lead on it. What exactly does cnf1 require? There is a lead on my adapter which is "reset via diode". Anyone know if this is equivalent to cnf1 pls?
    Many thanks
    please press
    the thanks button
  17. #14
    UK
    OP..Which interface & adapter did you use to connect using pcmflash please?
    please press
    the thanks button
  18. #15
    Jul 2014
    Hi mate
    Are you readed this ecu?
    I have the same ecu, and i need read it
