P2089? confirm P code
Yes, can confirm. its exhaust pressure sensor.
Nobody can help with ?
you have wrong pcode, try reading with other diagnosotic
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
read manual code and post here i can do dtc off, manual solution
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
OBD Code is P0472 (P2089 or 2089-02). Both means same. Circuit problem of exhaust pressure sensor... thats because its broken.
P0472 is allready removed in your file
Sedat Garip
Belgium
With Kind Regards,
I know. And the other one which present is P2089.
I deleted dpf and egr... and the stuff needen. But I need solution for the P2089 thing .
I will read with SD errors again.
i would also suggest try zeroing the pcodes itself not only increment/decrement and class
Problem solved?
