Results 1 to 3 of 3
    May 2010
    Poland
    Default EDC16U34 immo data swap
    Hello,
    I'm trying to find how to activate GRA-High in Skoda Octavia 2,0 TDI (BKD), ECU 03G906021LD. For first step I bought very similar ECU from VW 03G906021KK and I want to ask for immo swap from Skoda cluster to Golf ECU for check if this option will be enabled on "new" ECU. I know that in TSI it can be enabled. Cluster after my eeprom mod have this function, tested Skoda cluster in Scirocco.
    I have swapped almost all immo data from cluster to ECU, beside one MAC address which looks crypted in eeprom, My work in attachment, can somebody help with crypted part? eeprom_ECU.zip is almost copied immo data from cluster.
    May 2016
    It will be easier to transfer the immo data from edc to edc.
    You need to read immo data from the meter, not eprom.
    May 2010
    Poland
    I know that ecu>ecu is easiest, but MPPS v18 don't read eeprom by OBD on bench. I don't have car on place to unmount Octavia ECU for opening and read.
    Maybe I have to do a immo off on Golf and make test.
