Any help guys??
There is one Range Rover Sport 2016 that came to me for a spare key to be added, original key is Hitag Pro ID49 315MHZ, i tried to add key on car but it failed, i used VVDI2 to add key on the bench but when i got to car it says key invalid. So there must be something going on the file of the KVM itself maybe a security that prevents one from adding a key on obd or on bench.
Attached Files are the dump of the KVM untouched before any modifications.
any help is really appreciated
Any help guys??
What tool did you use to read KVM?
Sent from my SM-G930F using Tapatalk
VVDI PROG is what i used to read the KVM
Read KVM again, see the add key is registered.
Which tool u used to add key by obd?
Sent from my SM-J415F using Tapatalk
ifvyou first tried odb you bricked module
Does the ori smart key work now?
yes original key works good
doesn't vvdi prog on fk72 require you to lift crystal - basically have u read chip ok
Solidarity with Ukraine
i have read chip good and vvdi2 accepted files correctly.
