Results 1 to 10 of 10
    Jan 2016
    Default A4 B8 8K0909144P power steering B2000 foult
    Hi Guys..
    Anybody could clear internal foult B2000 in this unit (ST95320) ??
    Thanks in advance.
    Rgs.
    Jan 2016
    After reflashing all the same.. No foults in other modules.
    Romania
    Maybe you have damaged trabsistor in power stage, make a pricture with ecu and I will mark were to measure
    Jan 2016
    Reflashed it once again with VCP but it didnt do the job so maybe electronic is foulty or eeprom job ??
    Romania
    Measure betwen 1,2,3 and V+ and gnd, if have short in one transistor then need to replace ecu.
    Jan 2016
    It has 3 shorted to GND and V+.
    Quote Originally Posted by ghitab View Post
    Romania
    In this case other ecu.
  8. The Following User Says Thank You to ghitab For This Useful Post:
    amigokola (10th August, 2020)
    Jan 2016
    Somebody knows if there is a way to change only electronic part from other car ??
    I have some info that it can but didnt work in my case. Even after reflash and eep mod.
  10. #9
    Romania
    I did replace some and worked, try keep original ecu eep , some parameter inside eep used for sensor calibartion. Always connect supply voltage after secure ecu in place by screws.
  11. #10
    Oct 2016
    I have had same problem, replaced ecu and everything ok, i want to try repair old one, find out where is transistor located and replace it with non shorted transistor. Have somebody tried it?
