Results 1 to 15 of 21
    Jul 2012
    Default VW Passat B6 with edc17 decode 95320 eprom
    Can someone please help me decoding CCM 95320 eprom..? Need Pin and CS...
    Thanks for any help. Have complete engine ecu EDC17 readout to if needed..
    Jan 2018
    Post file from EDC17
    pin 10954
    cs F1 1C AC 87 E2 39 59
    Jul 2012
    Quote Originally Posted by Brat View Post
    pin 10954
    Thanks,
    here is engine EDC17 read file.
  5. The Following User Says Thank You to bobsey For This Useful Post:
    peetee25 (5th August, 2020)
    Jul 2019
    You need to read Flash and eeprom form ECu to be able to get data.
    Jul 2012
    Quote Originally Posted by immoneard View Post
    You need to read Flash and eeprom form ECu to be bale to get data.
    The file should contains all areas, mcu, flash and eeprom, at least that it was it says when I read it...
    Hungary, Mosonmagyar?v
    Hello
    Post ecu bosch number and upload file separate Flash , EEP
    Jul 2012
    I am not able to make single files from ecu read. But ecu number is 03L 907 309, Bosch 0 281 015 029.
    Is the pin and cs earlier in this tread ok?
  10. #9
    Jul 2019
    Not possible with file you posted , Read them separate.
  11. #10
    Jul 2012
    Default e2p and mpc separate
    here should e2p and mpc be separate files.
  12. #11
    Jul 2019
    Your files are not good , what tool you using to read ECU and is it Master or Slave unit?
  13. #12
    Jul 2012
    Hmm... cant understand that. Files is read with genuine Dimsport newGenius slave and encoded from master and sent to me after. So they shouldnt be unpacked or anything.
    Could it be after rar packing there is something wrong?
  14. #13
    Romania
    Maybe dimsport encrypt real data,try othre tool. But why need ecu now as CS and pin you have from ccm in post3 ?
  15. #14
    Jul 2019
    Quote Originally Posted by bobsey View Post
    File are encrypted , they not regular files .
  16. #15
    Jul 2012
    Could be, but cant understand that as it comes from master... but is pin and cs from post ok?
