    Apr 2020
    KSA
    Default Ford Taurus Clear Crush
    Hello Every one, can someone clear crush this file from ford Taurus Airbag 2015 read by UPA.
    P/N: EG13 - 14B321 - BA
    superjet's Avatar
    Aug 2018
    write and clear errors,report
    pm
    Apr 2020
    KSA
    hello m8, the crush data deleted but the new code U3000:49 control module is present. can you help to erase it?
    superjet's Avatar
    Aug 2018
    write your ori file to check it have U3000 or not
    Apr 2020
    KSA
    before no code U3000, after write the clear file then it will come, the crush code delete but U3000 is present, I write the orig file back and same both are present B1193 and U3000. you have any Solution?
    superjet's Avatar
    Aug 2018
    do you test in car and replace all damage parts for SRS?
