punto grande iaw 5sf3.m2
Results 1 to 15 of 15
    Jan 2016
    Default punto grande iaw 5sf3.m2
    The customer's computer is burnt out due to short circuit ( his own fault )
    ,he buy a second-hand computer, I made it Virgin, car started but run not good ( max 4000 rpm ),,
    I tried to learn throttle body again, everything has been reset with Delphi ( Calibrate rpm sensor + Reset adaptation values + Reset vehicle configuration + Learning throttle adaptation ) , after that I wanted to make proxy settings, but comminication with BSI is not posible !
    any advice ? can someone make it virgin again , maybe my virgin file were not ok !
    Feb 2010
    file virgin
    pass pm
    please report
  3. The Following User Says Thank You to pinotec For This Useful Post:
    mrchip (6th August, 2020)
    Jan 2016
    Quote Originally Posted by pinotec View Post
    file virgin
    pass pm
    please report
    Thank you so much Pinotec, Your file looks good, immo bits are at the same adress like I did it before,but I did only FF FF ,yours are different
    I will test it and report back
    Meat-Head's Avatar
    #phonic wheel
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
  7. #5
    Jan 2016
    Quote Originally Posted by Meat-Head View Post
    #phonic wheel
    please tell me more about that,, you are right, I get every time that DTC code P1300-55 Phonic wheel learn
    I cant make proxy allingment ( cant communication with BSI ),, how to fix Phonic wheel,, after I did reset ( with Delphi ( Calibrate rpm sensor + Reset adaptation values + Reset vehicle configuration + Learning throttle adaptation ) car wont crank,, I hear relay clic in fuse box ( engine side ), I did bypass starter motor relay,engine crank well but not start
  8. #6
    Jan 2016
    Hi dear Pinotec , your file is OK ! key is self learned after first ignition on , but I cant still get communication with BSI, I think car has more another wiring or module's probleem
  9. #7
    Feb 2010
    if you want try immo off for start car , but no resolve the problem on bsi..
    used ecu is equal at ecu broken ?
  10. The Following User Says Thank You to pinotec For This Useful Post:
    mrchip (7th August, 2020)
  11. #8
    Jan 2016
    if you do have immo off solution it will be very nice, then bsi will be removed from immo system,
    I can rule it out as a cause , donor ECU has same partnummers
  12. #9
    Feb 2010
    same password, disconnect antenna
    please report
    regards
  13. The Following User Says Thank You to pinotec For This Useful Post:
  14. #10
    Meat-Head's Avatar
    Phonic wheel get engine warm, hit rev limiter 2 seconds, do this 3 times wait few seconds turn off
    Something to do with cam algnment
    source:- some bloke with cancer
    not sure on your problem but try whatever fresh file you have
    turn ignition on for few minutes, make a cup of coffee THEN try starting
    as ecu is learning if auto (no clutch switch) or manwel (clutch switch)
  15. The Following User Says Thank You to Meat-Head For This Useful Post:
  16. #11
    Nov 2009
    If dash, lights, central locking, windows work ok, then bsi is good, but your diag tool not. Try other, eg mes and see if you can communicate with bsi.
  17. #12
    Nov 2009
    I agree with Meat-Head - phonic wheel.
  18. The Following 2 Users Say Thank You to drz For This Useful Post:
    Meat-Head (8th August, 2020), mrchip (7th August, 2020)
  19. #13
    Jan 2016
    please report
    regards
    Dear Pinotec, I wrote your Off file, tried first without key, immo light on , car wont start,,then connected antenna --> immo light off, key code learned --> car dont crank
    maybe I did it wrong , not waited, started too quickly
    problem is RPM not higher than 4000 , it must 5000-6000 for cam alligment, maybe I did it wrong, after writing Pinotec his file I started the car too quickly, nex time i will take time for an make up or coffee
    Quote Originally Posted by drz View Post
    I cant get communication with BSI, tried with Fvdi, multiscan, elm327, delphi, today tried other BSI, same result, no communication for proxy alligment,, ( i can get communication with other module's on canbus line )
    thanks to all, to be continued
  20. #14
    Meat-Head's Avatar
    Hang on
    rumor states the poxy alignment is for bsi, instrumental, radio (not sure air bag)
    OFF TOPIC:-
    a ducato van is nothing more than an over fed punto you do srs poxy alignments in bsi
  21. #15
    Feb 2010
    please report
    regards
    if possible try new file
