Results 1 to 7 of 7
    Feb 2018
    Default Passat B5 Dash to New Mode
    I've got a used dash (3B0920849C) from a passat b5 and want to set it to "new mode" so the immobilizer isnt adapted, mileage to 0, no vin. I know I can adapt the immo/dash with pin but want to try/learn something new.
    Anybode could explain/show it how to do it?
    Jan 2019
    Quote Originally Posted by maktusch View Post
    Hi maktusch, do you have the dump for the 3B0920849C?
    Greetings
    Feb 2018
    Yes, I've got the dump. You could hep?
    Jan 2019
    Put the dump here and I will check it out. I will try to virginize the dash. So you can compare both files.
  5. The Following User Says Thank You to GolfFSI For This Useful Post:
    maktusch (10th August, 2020)
    Feb 2018
    Ok, heres the file. Thanks in advance.
    Romania
    Courius why need new mode?
  8. The Following User Says Thank You to ghitab For This Useful Post:
    maktusch (11th August, 2020)
  9. #7
    Feb 2018
    No real reason, only want to learn something because I didnt found that much information about "new mode" on the internet.
    Thank you, I will have a look!
