Results 1 to 2 of 2
    Apr 2016
    croatia
    Default citroen C 1.4 I 2004 BSI damage with FVDI
    I've tried to read PIN with FVDI on a Citroen C4 1.4I 2005 FVDI said that couldn't read the PIN
    The car dashboard doesn't respond any more, and ignition ON doesn't do anything.
    can anyone help me , can some solution or suggestion
    thank you
    96 601 059 80
    BSI 2004 H05-01 290805
    BOOT 21676031-5B
    HARD 28113346-8A V02-00
    281148373A
    F0143034
    rob h's Avatar
    May 2011
    Read the bsi again, it might come back to live.
    This time, use battery suplier, or good charger.
    It might work.
    If it fails, you should look for a healty flash file, and write that.
    Best to do that with a bench setup.
    https://www.digital-kaos.co.uk/forum...ght=9660105980
