Results 1 to 8 of 8
    levisdj's Avatar
    EcuLand
    Default Astra H 1.9 CDTI DPF EGR
    Hi, need help with astra H 1.9 cdti with dpf and egr off... I have tried different solutions without result .... ads don't work either ... car after 30 seconds won't rev above 2000 rpm .... bdm flash attached thanks!
    levisdj's Avatar
    EcuLand
    Hi, still need this.... thanks!
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by levisdj View Post
    here you go tested solution
    pass in pm
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  4. The Following User Says Thank You to chrisimerk For This Useful Post:
    levisdj (6th August, 2020)
    levisdj's Avatar
    EcuLand
    Hi, thanks for your reply.... I wrote the file but the problem remains ... after 30 secs no rev above 2000 rpm
    chrisimerk's Avatar
    Dec 2018
    England
    this manual solution done many on here so no idea why not working mate ill look into it for you
    (DEMON DEVELOPMENT)
  7. The Following User Says Thank You to chrisimerk For This Useful Post:
    levisdj (7th August, 2020)
  8. #6
    johak's Avatar
    here you go
  9. The Following User Says Thank You to johak For This Useful Post:
  10. #7
    johak's Avatar
    here is dpf and egr
  11. #8
    chrisimerk's Avatar
    Dec 2018
    England
    have you reset dpf with diag and unplugged pressure sensor and EGT sensors
    (DEMON DEVELOPMENT)
