Results 1 to 11 of 11
    Nov 2018
    United Kingdom
    Default CAS 3 FAILED TO FLASH ... PLEASE HELP
    Hello all,
    CAS 3 failed to reflash and now the flash file is all FF, I've tried few flash files, but none is waking up the CAS, please help.
    Please find attached the CAS label and EEP and FLA read.
    Thank you
    pepi's Avatar
    Nov 2018
    United Kingdom
    Hi, thank you for the reply, unfortunately my programmer is accepting only 512K bin files, the one there is 2mb, probably downloaded with something else.
    Thanks G
    May 2020
    tot557545@gmail.com
    gogoshkin12
    hi help you chk calculated cas3+ eeprom,write to cas3+ and ok
    rep + thnx button for help
    VIN: WBAVN32030VL52785
    ECU ISN: 1FA53F3008895FAF2DABC960F457AD66
    Nov 2018
    United Kingdom
    Hi, thank you for the help, my initial issue was the flash as that's what failed to reflash, the eeprom is/was good.
    Thanks G
    Europe
    I guess this flash should work, but I can't tell for sure where it's from and if it's any good.
    No harm in trying though.
    Aug 2015
    Germany
    here a flash that SW number matches to your eep
    Nov 2018
    United Kingdom
    Hi, as soon as click on the link it's throwing me to the login menu.
    Could you be able to send it over email?
    Thanks G
    Nov 2018
    United Kingdom
    I had this one, it wouldn't work.
    Thanks G
    dimitar's Avatar
    Put similar flash than use winkfp in expert mode to reflash
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Changing flashes or Winkfp wont help.
    This is your working solution.
