Results 16 to 30 of 31
  1. #16
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by ant21 View Post
    mercedes
  2. #17
    Quote Originally Posted by Andywill View Post
    I have a problem with my Merc Star3 not communicating with any Merc vehicle Gateway module, this prevents diagnosis of any module not directly connected to the CARB socket. All other functions/comms of my Star3 are working fine that do not rely on comms with the Gateway module. The Star3 has a self diagnosis programme in Star Utilities - Self Diagnosis - Caesar. With the Star3 connected and powered up, this programme will perform a internal integrity check, I've attached a copy of my Star3 report for reference of what one looks like.
    Would someone with a Star3 execute the same and upload the report for comparisons.
    Thank you.
    check that your multiplexer authorized level is 3, it is old dear, the new one is authorized level is 4. check it. please try YOU HAVE BEEN WARNED BEFORE MATE >>>>>> you will get level 4 report
  3. #18
    DK Veteran cocutanu's Avatar
    Jun 2009
    @ andywill
    My friend...you're problem has nothing to do with serial number or authorization level !
    I saw many , actually many more with the authorization level 4 and serial number 029866 which has this problem plus k-lines errors instead of D3 with s/n 27685...
    The problem is related to poor voltage stabilizers and cheap capacitors...it's a guy here who knows this problems very well...Bigovic. Try to PM him for some sollutions.
    No offence for this guys from anyscancn but definately they will tell you that their stuff is better because they are selling this !
    And by the way mine is D3 with s/n 27685 and working perfect for about 4 years but it was made in Europe.
  4. #19
    Das error 9500 help from someone. THANKS
  5. #20
    Quote Originally Posted by cocutanu View Post
    @ andywill
    you mean your mulpex is D3, please try with x entry, does it work on W212, 207,, looking forward to your reply. thanks mate
  6. #21
    thank you very much!!!
  7. #22
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Quote Originally Posted by mercis View Post
    new mux:029866
    cesar selfdiagnoe.all ok
    I have a mux # 0299866 and I get the same bloody error - (I just received it and checking it !!)
    Selfdiagnostic
    Device: Part D
    Toolkit-Resultcode: 1
    SDconnect Toolkit - device diagnostic - Part D
    CAESAR STOS+ Rev.:2.12 from Jun 16 2005
    generated protocol file from 13.07.2010 22:22
    SystemCheck :
    Check serial ... 0 Ok
    CAESAR HW Detection :
    D2Access ... 0 Ok
    D2DownLoad ... 0 Ok
    CAESAR Part D2 detected on COM2 with baudrate: 19200
    CAESAR version check :
    D2CheckSNVER ... 0 Ok
    User is Daimler-Benz AG
    User Authentification 1
    Classification 0
    Serial Number 029866
    Authorization Level 4
    Part D
    Hardware Authentification 011205
    Hardware Date 031205
    Special EEPROM check : D2
    Special EEPROM check:
    Inst. date registered ... 0 Ok
    D2 Special CAN Test :
    Special Test ... 3001 Error in CAN1 environment on Part D2 board
    Classification 0
    Part D
    Slave check :
    D2 Slave check
    D2 Processor ... 0 Ok C165 (mask step CA) is mounted.
    D2 RAM ... 0 Ok
    D2 FLASH ... 0 Ok
    D2 EEPROM ... 0 Ok
    D2 SERCTL1 ... 2003 DSR / DTR lines at UART1 not connected
    D2 UART1/2 ... 0 Ok
    D2 ADC ... 0 Ok
    D2 Display Power Supply :
    D2 Power Battery ... Voltage KL30 = 12.5 V
    D2 Power Ignition ... Voltage KL15 = 00.3 V
    D2 Voltage K-Lines :
    D2 State K-Lines (35) ... Total 2 (+), 33 (-)
    So where do we go from here ????
  8. #23
    ....yep. Had very similar on my old one, if you can, check OBD socket pins 6 and 14 with star connected and trying to communicate, if no can signal appears - its dud! But the self test seems to have confirmed it for you.
  9. #24
    Hi there
    More to come
    Trying to test again and I get :
    Selfdiagnostic
    Device: Part D
    generated protocol file from 13.07.2010 22:43
    SystemCheck :
    D2Access ...
    103 No D2 Hardware connected
    No CAESAR components / Errors during detection
    The thing is I am using an RS-232 Express Card, and I suspect it is not working all that good.
    Message :
    D2 SERCTL1 ... 2003 DSR / DTR lines at UART1 not connected is probably trying to spit that out !!
    What do you make od all this ??
    (As far as I am concerned , I am going down to the garage to run a few tests again!! - and it is 02:00 in the night!!!)
  10. #25
    I forgot to mention I am running DAS 2010.01 on VMware.
    Also use COM port 2 on both Host and VMware with Max speed 115200.
  11. #26
    Quote Originally Posted by gmatj View Post
    Still I got no solution !!
    If anybody has had similar experience please contribute to the thread.
  12. #27
    diagnoza_auto2000's Avatar
    Sibiu
    Firts open your mux an resolder with hotair can controlers both of them and Saf procesor.
    Maiby some line not have a good contact.
    If will not work i will give you another solution,pm pls
  13. #28
    Hi all,
    I have the following error on my star das:
    1.1-1.501.9302
    What do you you think about this error?
    I can't see D2 Power battery and D2 Power ignition.
    On PCB I have 12v but not in diagnose.
    I replaced a faulty 7808 IC inside the multiplexer but nothing was changed.ADC converter was replaced also with the new one-without any result.
    Something not work on the supply side:
    D2 ADC ... 2500 Error ADC
    D2 Power Battery ... Voltage KL30 = 00.6 V
    D2 Power Ignition ... Voltage KL15 = 00.2 V
    D2 State K-Lines (35) ... Total 0 (+), 0 (-), 35 Error(s)
    Thank you.
  14. #29
    Just reporting back --(I should have done earlier...)
    Changed RS-232 card and system is Ok now.
    The one I use now has Oxford Chipset and of course coresponding drivers.
  15. #30
    Dec 2011
    Default 3001 Error in CAN1 environment on Part D2 board solution
    hello all
    i have this problem my cesar
    can fixed
    1-first check obd socket volt
    must 12v
    and change obd cable
    %100 work
    good work
    kenwood
