Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Dec 2009
    Default Mercedes DAS Star3 users.....
    I have a problem with my Merc Star3 not communicating with any Merc vehicle Gateway module, this prevents diagnosis of any module not directly connected to the CARB socket. All other functions/comms of my Star3 are working fine that do not rely on comms with the Gateway module. The Star3 has a self diagnosis programme in Star Utilities - Self Diagnosis - Caesar. With the Star3 connected and powered up, this programme will perform a internal integrity check, I've attached a copy of my Star3 report for reference of what one looks like.
    Would someone with a Star3 execute the same and upload the report for comparisons.
    Thank you.
    Jul 2009
    Quote Originally Posted by Andywill View Post
    Thank you.
    My org head has the same result only baud rate is 115200.
    Dec 2009
    yours has the same CAN error logged....??? Mine is a clone and has worked fine until recently. Cable continuity has been eliminated.
    would you mind posting/sending a copy of your report?
    Jul 2009
    Sorry no error on Can
    Dec 2009
    Thanks for the confirmation. If you have a copy of your report that would be great.
    Nov 2009
    Common issue with the Chinese MUX clones.
    I shipped my MUX back 3 times and I just gave up on them.
    Regards,
    JR
    Dec 2009
    JR2 - thanks. Who did you buy from? Do you now have an original?
    SadCriss's Avatar
    Jan 2010
    At the Garage
    Hi,Can you make any comunication whit any of the cars?1. you should check COM setings need to be on COM2 and Bit per second 115200.2.If all these ok Please type down the error what you hawe exactly.Or P.M me for contact each other.B.R.
    If It helps you try push the: Thanks and REP
    I do the same each time it helps.
    Aug 2009
    hello with witch laptop you use mb star
    Dec 2009
    SADCRISS and MOTORSPORT - thanks for the reply. I am running IBM T30. I can comminicate with any module on any car providing i dont need to access the gateway controller eg. diagnosing airbag on SL500 W230 is run through the gateway and i can not access this. Any controller with a direct line to the CARB socket i can communicate no problem. Also when selecting a vehicle from the menu, the Star3 seems to da a quick check of the Gatway for correct vehcile ID - it fails this and asked to enter the vehcile details manually. Before this problem it would pick up the vehcile automatically.
    How do i check the comm settings? All i have is the self CAESER report attached, does this necessary info?
    Any further help would be great.
  11. #11
    Nov 2009
    workshop
    i have same problem,my china dealer change mux,
    this is error in production,mux nr.027685
  12. #12
    Dec 2009
    Yes, my serial no. seems to be the same 27685.
    Merci - did you get a new MUX, what serial no. was that?
  13. #13
    Nov 2009
    workshop
    new mux:029866
    cesar selfdiagnoe.all ok
  14. #14
    Dec 2009
    Great thanks. So the serial number 27685 is not my individual number then, if you had the same serial number.
    Where did you purchase your from please?
  15. #15
    Nov 2009
    mercedes
