Hello !
W211 from 2002 have SBC unit brake , you need one complete test on brake system with MB star or similar good diagnostic unit . Check brake pressure and check internal brake switch counter .
BR
My w211 from 2002 some times not usually show me at displey red message brake defective visit workshop. There are acustic signals to. When I stopped engine and start again message go out and car driwe normal. No fault found at display after message go out. Is danger driwe this car? During driwing never happened. What can be reason for this? I know one reasons are car years but what can be another reason please?
6841707059 576F526B 57416E5453 596F55 526F6B69424152
Hello !
BR
rokibar (9th August, 2020)
Thanks friend. I will do it.
i make diagnostic and there are not fault code.
sbc das.rar
here some values
Hello !
This values is ok , do you make complet short test ?
on this model there is a counter press the brake pedal
reset it
PRESS THANKS AND REPUTATIONS (STAR) BUTTON
I don't give others the password to the file. I'll send my file and I'll try to make it
I go direct at sbc and esp. But thinking problem can be in small battery which have 12.3 v yesterday. battery start with charging several sec after starting the car so this several sec can causing undervolage problem if batery go down. Charging is ok and it is 13.7v. All stay open and I will come back with results.
If IT is a reset job, like Robert1232 posted.
https://www.digital-kaos.co.uk/forum...-counter-reset
The counter,, Will leave dtc.
And you have no dtc?
Is there a Brakel fluid conductivity sensor on these?
Change fluid,
Thanks for inputs guys. Not easy resolved it when problem presents some times and go off after switch ignition off on. Dtc stay in stored section only.
