Results 1 to 11 of 11
    May 2017
    Espaņa
    Default EWS3 2D47J erased and synchro
    Hi guys, i have a car with ews3 with 2d47j erased because somebody tried to read as 0d47j...
    I have a dump from same version, but need to syncro EWS and MS42. I have avdi genuine but cant do syncro, always show incorrect status. I tried to iimoerase ms42 and do syncro with same result.
    Can somebody do a manual syncro between ews3 (donnor) and original ecu from car? VIN from car is WBAAM51070EZ40977
    thanks!
    KriptoKey's Avatar
    Feb 2012
    WRITE PLEASE ONLY EWS
    Quote Originally Posted by hrmotorsport View Post
    thanks!
  3. The Following User Says Thank You to KriptoKey For This Useful Post:
    hrmotorsport (7th August, 2020)
    May 2017
    Espaņa
    Hi sir, car not crank, i maje syncro with avdi but still same problem.
    Enviado desde mi iPhone utilizando Tapatalk
    Apr 2016
    new transponder programmed we hope?
    Europe
    No crank means key is not correct, it has nothing to do with sync EWS-DME.
  7. The Following User Says Thank You to tomvleeuwen For This Useful Post:
    hrmotorsport (10th August, 2020)
  8. #6
    May 2017
    Espaņa
    Yes sir, new transponders was created with your file
  9. #7
    May 2020
    tot557545@gmail.com
  10. The Following 2 Users Say Thank You to ecuprogramer For This Useful Post:
    dobribg (9th October, 2020), hrmotorsport (9th August, 2020)
  11. #8
    May 2017
    Espaņa
    Thanks sir i already downloaded another pair of files and working too but thanks a lot . I apreciated so much.
    Br
  12. #9
    KriptoKey's Avatar
    Feb 2012
    If the key is properly programmed, the engine should turn and turn but not start. to start the engine you need synchronization.
    If the motor does not turn you have a problem with the EWS.
    luck
  13. The Following User Says Thank You to KriptoKey For This Useful Post:
  14. #10
    May 2017
    Espaņa
    Yes i know, with your dump i make a tp, but no crank. With another pair of files i do one more tp then car crank and engine on.
    But thanks a lot for your help. I apreciate
  15. #11
    Feb 2019
    pelace send pass for dumb
