Dears , i need to do immo off to this ecu , this is after 2014 i tried many softwares without success i attached the eeprom and flash , i can pay for the solution
Only try to use mpc. If it doesn't work, put e2p.
FILE SERVICE 24/7
Stage 1 / 2 / 3 - DPF / FAP / EGR / SCR / NOx / TVA .. etc
Tools-Master: Autotuner / Flex / Trasdata / IO-Terminal / Launch Euro TAB II
Genuine software: WinOLS, ECM , tuning software etc ...
TECHSIX.NET - PLEASE BE CAREFUL THIS SCAMMER !!!!
http://www.techsix.net/
zecozc (11th August, 2020)
NOT Working , this solution is like the one i have got from https://www.weboctopus.nl/edc17-med17-immo-off.php
this ecu is different
may need to correct cs in flash before writing
thank you , i will test and inform you
Do you have news...??
