Results 1 to 2 of 2
    Aug 2020
    Default Little help with DPF off audi a 4 170ps BRD engine
    The car entered in forced regeneration but failed to do it for 10 times - DPF light on, glowplug light flashing, check engine and low power.
    I physically removed the DPF content and welded, I removed the P0299 low power error with vcds and Check engine light went off. The car is still in limp mode with DPF and glowplug lights on.
    There are few more codes all related to dpf due to removal.
    I got the ECU file read with kess v2
    If someone can look at the file and remove the DPF related stuff, any help would be much appreciated (not sure about the dpf light on the dash).
    Thank you!
    mrjay88's Avatar
    Apr 2018
    UK
    here u go pass in pm
  3. The Following User Says Thank You to mrjay88 For This Useful Post:
    crysty3h (8th August, 2020)
