Results 1 to 15 of 19
    Dec 2015
    Portugal
    Default Volvo CEM how to read Flash 28F400
    Any tip how to read Flash 28F400 or remove the metal frame from CEM?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Just cut frame,if you want desolder
  3. The Following User Says Thank You to drugowaz For This Useful Post:
    lmqcatarino (9th August, 2020)
    AND http://www.digital-kaos.co.uk/forums...=1#post3196027
    28F400 wery sensitiwe hot air
  5. The Following User Says Thank You to janusz21 For This Useful Post:
  6. #4
    rob h's Avatar
    May 2011
    Jtag Smok programmer can read these.
    I read 1 unit, worked well.
    No need to remove it.
    https://obdtool.nl/index.php?route=p...56&search=jtag
    The programmer, plus licentie for cem, 160Euro.
    The programmer itself, does have some free eeprom function, and all payable option like micronas, renesas, etc work really well.
  7. The Following User Says Thank You to rob h For This Useful Post:
  8. #5
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by rob h View Post
    or this... great stuff for 50usd
  9. The Following 3 Users Say Thank You to jodge For This Useful Post:
    Cromwe11 (11th August, 2020), Faraday (23rd August, 2020), Zmann (11th August, 2020)
  10. #6
    rob h's Avatar
    May 2011
    Have considered buying it, there are some posts out there. Cheap for sure.
    Did not find many good results posted.
    Ruining the cem, would have cost me more thaen 50usd, and more then 160E.
  11. The Following User Says Thank You to rob h For This Useful Post:
    whiskeyman (9th August, 2020)
  12. #7
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    or get a nice chunky solder iron and bend a wire too shape for both sides
    just watch dont fry anything
    https://www.youtube.com/watch?v=xMXJTLWyBCo
  13. The Following User Says Thank You to whiskeyman For This Useful Post:
    lmqcatarino (10th August, 2020)
  14. #8
    rob h's Avatar
    May 2011
    I ordered one of these, form China.
    A1259B hot air nozzle.
    Soon as it arrives, i will try it.
  15. #9
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by whiskeyman View Post
    That is horrible looking method.
    I have no idea why even try something like this. Hot air is quicker, safer and just more proffessional...
  16. The Following 4 Users Say Thank You to p1et For This Useful Post:
    fred77 (17th January, 2024), lion0304 (11th August, 2020), lmqcatarino (10th August, 2020), musti418 (9th August, 2020)
  17. #10
    whiskeyman's Avatar
    Dec 2010
    Quote Originally Posted by p1et View Post
    i remember when flooding with solder was safest method
  18. #11
    lion0304's Avatar
    Oct 2014
    Hot air station, TL886 + Adapter, quickly and job done.
  19. The Following User Says Thank You to lion0304 For This Useful Post:
    p1et (9th August, 2020)
  20. #12
    Dec 2015
    Portugal
    Thanks to all.
    I will look for Jtag Smok programmer.
    I think it's the easiest and clean way.
    I hope it will be safe read and write Flash by BDM.
  21. #13
    jodge's Avatar
    Mar 2017
    i guess you are not familiar with the JTAG based protocols it's an official well documented development/debug port not some cracking/hacking/messing stuff
    you unable to fry anything no matter the tools unless if you mixing the pinout
    You have to providing the mcu loader(s) if you unable to doing that you get an exception (error message) thats all
  22. The Following User Says Thank You to jodge For This Useful Post:
  23. #14
    Mar 2014
    West Sussex UK
    Quote Originally Posted by jodge View Post
    +1 for this had one for about six years only use it for Volvo CEM’s paid for itself a 100 times over.
  24. #15
    Dec 2015
    Portugal
    Hi, and thanks for all suggestions.
    I didn't get any response from smok, so I had to go on harder way.
    So I cut the metal frame and could remove flash from CEM and read it with VVDI-Prog.
    Open file with tango. There was 3 keys programmed, so I program transponder on key 3 position and generate new file.
    Then I open that file and program another transponder on 4 key position. New file saved.
    Then I write last file to flash.
    All ok. Transponder key 3 start car.
    There was an accident with transponder key 4 and lost it.
    It's possible program a new transponder without need to write new file again to flash?
