Results 1 to 15 of 15
    Nov 2019
    ENGLAND
    Default VW T5 TRANSPORTER EDC17CP20 VMAX OFF
    Hi, struggling to locate the vmax in this file if anyone knows where it is would be great
    Its limited to 70mph
    Thanks, Ant.
    Sep 2009
    in adress 44B4B change 01 to 00
    try an report
  3. The Following User Says Thank You to goran81 For This Useful Post:
    Antastra1989 (12th August, 2020)
    May 2020
    tot557545@gmail.com
    Antastra1989
    upload flash file no .MPC .....
    Nov 2019
    ENGLAND
    Default transporter
    This is all i have read with ktag
    eeprom and maps
    Thank you.
  6. #5
    Nov 2019
    ENGLAND
    anyone got any ideas
    Thanks.
  7. #6
    Mar 2016
    Quote Originally Posted by Antastra1989 View Post
    Thanks.
    Try this from adress suggest , no checksum , and report
  8. The Following User Says Thank You to PaoloDigital For This Useful Post:
  9. #7
    Nov 2019
    ENGLAND
    Speed limiter still on using the switch solution
  10. #8
    Nov 2019
    ENGLAND
    Default do you think it could be in eeprom
  11. #9
    Sep 2018
    Universe
    Hi, post your ecu label, more info about ecu,,,
  12. #10
    Nov 2019
    ENGLAND
    photo of ecu
    thanks.
  13. #11
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    have you got autel ? easy to change
  14. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    Antastra1989 (15th August, 2020)
  15. #12
    Nov 2019
    ENGLAND
    Not thought of that tbh will give it a go buddy
  16. #13
    Mar 2008
    birmingham
    login code 12233 in coding first
  17. The Following User Says Thank You to smirnoff_rules For This Useful Post:
  18. #14
    Nov 2019
    ENGLAND
    Legend, will try it out in the next hour.
  19. #15
    Nov 2019
    ENGLAND
    Worked like a charm mate your a legend
  20. The Following User Says Thank You to Antastra1989 For This Useful Post:
    smirnoff_rules (15th August, 2020)
