Results 1 to 5 of 5
    Mar 2014
    Default Alfa 156 instrument cluster wiring diagram
    Hello guys,
    I'm having a trouble with Fiat Tipo project I'm working on.
    Tipo is from 1988 year. Engine 2.4 jtd 150 horse power 10 valves from Alfa Romeo 156 is under the hood now. My job was to connect engine, abs and instrument cluster wiring.
    I got the wiring from alfa in parts, and a lot of wires were cut.
    We managed to put it together, even tho we didnt have the right wiring diagram.
    The problem we are having is that RPM scale on instrument cluster is not working.
    I cant find the right wiring for RPM.
    Can anyone help?
    Cheers!
    Last edited by pizdun9245; 10th August, 2020 at 08:41 AM. Reason: Title doesnt discribe problem
    Meat-Head's Avatar
    Cool pictures or it didn’t happen
    is it the tipo cluster or the one for the engine?
    does it have body module or just immo off?
    Nov 2009
    No body module in alfa 156. Not so sure for rpm signal, will check tommorrow.
    Meat-Head's Avatar
    In that case would expect direct pin out from ecu
    Nov 2009
    Yes, should be brown/white wire from ecu to dash (pin 6 but don't know which connector).
