Results 1 to 8 of 8
    Apr 2016
    Default ASTRA H 1.7 Z17DTR 125KW NEED DPF OFF WITH COUNTER STOP
    hello dk, i need a working dpf solution. after writing the dpf off, the counter dont stop working and after a few km the glow plug light flash. I need a solution with a stop counter.
    best regards!
    NCLAP40R
    W0L0AHL3582031208
    Z17DTR
    DECe01
    DENSO0100
    jurebv's Avatar
    Dec 2017
    Croatia
    write original, reset/set dpf replaced on original with diagnostic before writing my file
    Best Regards
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  3. The Following User Says Thank You to jurebv For This Useful Post:
    eculevel (10th August, 2020)
    Apr 2016
    Quote Originally Posted by jurebv View Post
    Best Regards
    my friend, file don't work, dpf counter work again..
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    HI
    DPF OFF, CHECKSUM CORRECTED
    PASS IN PM
    REPORT BACK
    THANKS
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  6. The Following User Says Thank You to momogsm For This Useful Post:
    Apr 2016
    Quote Originally Posted by momogsm View Post
    HI
    PASS IN PM
    REPORT BACK
    THANKS
    don't work, after 15km dpf counter 3%..
  8. #6
    momogsm's Avatar
    HI
    SAME PASS
    REPORT BACK
    THANKS
  9. #7
    Apr 2016
    HI
    SAME PASS
    REPORT BACK
    THANKS
    Dpf Counter always work my friend..
  10. #8
    jurebv's Avatar
    Dec 2017
    Croatia
    dpf counter increases but regeneration or error never happens
