Results 1 to 2 of 2
    Apr 2016
    Default GOLF MK4 RHD 2002 - 2004 Software Coding & Workshop coding
    Hi All
    I have hit a brick wall and need help a.s.a.p
    Im busy with a Golf Bora MK4 1.6L RHD
    Problem - Driverdoor Windows & Central Lock Control Unit only opens/closes the driver side window(not every time) no other windows works through the unit. Central Lock and Unlock also works now and then.
    Scanned for fault codes and gave on the Gateway an error that the CAN Gateway is coded incorrectly. No Communication with the ECU.
    Wiring was checked from ECU, Cluster, CAN Gateway, Instrument Cluster, Door Lock and Window Modules.
    Checked the continuity from each unit, Earth points and Power Feeds.
    The following values i have written down as a guideline to solve this issue.
    17. Instruments
    Vag Number: 1J5920825A
    System Designation: A4-KOMBIINSTRUMENT VDO V09
    SWC: 05102
    WSC: 23352
    XTRA -1 IMMO IDENTIFIER Number VWZ7ZOY2784665
    ECU PROTOCOL KWP 1281 KLINE
    19. CAN GATEWAY
    VAG NUMBER: 6N0909901
    SYSTEM DIAG GATEWAY K<-> CAN 0001
    SWC: 00004
    WSC 31414
    ECU PROTOCOL: KWP 1281 KLINE
    01. ENGINE
    VAG NUMBER: 06A 906 019 BQ
    COMPONENT: 1.6L V2/R4 SIMOS 3318
    SWC: 00031
    WSC: 31414
    EXTRA: IMMO-IDENTIFIER VWZ7Z0Y2784665
    IMMO
    VAG NUMBER: 1J5 920 825 A
    COMP A4-KOMBIINSTRUMENTSVDO V09
    SWC: 00102
    WSC: 23352
    EXTRA IMMO IDENTIFIER NUMBER VWZ7Z0Y2784665
    The CCM identification Code is 1C0 959 799 B
    with the scantool i can read the pin code from the instrument cluster, immo and ecu.
    Lastly the fuses is all good
    the interior lights work only when switched on, the hooter relay kicks in but does not sound.
    the door lock with key when turned locks and unlocks the driver side, also when open the window rolls down, closes when you lock the door.
    appreciate any help or guidelines.
    Sep 2013
    Hello, i have the same problem with Toledo MK2, have the same confort and gateway module, my door lock works , but the windows dont works, i think is the gateway, and have in confort line in canbus high 12v, any can help.
