ford c max 1.6tdci dpf remove
Results 1 to 3 of 3
    Default ford c max 1.6tdci dpf remove
    Can someone remove dpf from
    cmax 1.6tdci 80kw 2005year, edc16c34,
    dtc`s p242f and p2585
    limp mode.
    thx
    BR
    Apr 2020
    Quote Originally Posted by niki85 View Post
    limp mode.
    thx
    BR
    file for you, pass PM
    dont forget press thanks and reputation button
  3. The Following User Says Thank You to ZiZiTun For This Useful Post:
    niki85 (11th August, 2020)
    May 2020
    tot557545@gmail.com
    niki85
    hi help you dpf off egr off and dtc error code off good and ori solution...
    Fuel additive Control Module neew be disconnected
    rep + thnx button for help you
