Results 1 to 5 of 5
Thread: audi a4 rb4
    Mar 2017
    Usa
    Default audi a4 rb4
    Hi.audi a4,2003,diesel,dashboard-rb4.I need to change the dashboard.
    after replacement component security, I have:
    eprom uk - all work. vag-com - no mistakes.
    eprom eu - speedometer needle does not work and does not count mileage.
    vag-com - 1 error-no communication with the gearbox.
    Transmission-mechanical.how to change automatic to manual ?
    correct the dump if possible so that there is no error.thank.
    Aug 2015
    Latvia
    Hi, your EU cluster is old, MJ 2001, and have different speed signal source . You must change in EU eeprom 0x33a data from 21 to 31, write it, and all must be OK.
  3. The Following 3 Users Say Thank You to armi For This Useful Post:
    armirad (14th August, 2020), immoneard (15th August, 2020), rtbdiagnostic (14th August, 2020)
    brend's Avatar
    Oct 2015
    Same where
    For good job with R4/RB8 need put dash to virgin mode then coding this to car .All job only obd2 away.
    Just swap eep .....this sulution not for this dash type.
  5. The Following User Says Thank You to brend For This Useful Post:
  6. #4
    Mar 2017
    Usa
    changed 21 to 31 and it worked
    Aug 2015
    Latvia
    I am glad that my knowledge about audi crypted clusters helped you.
  8. The Following 4 Users Say Thank You to armi For This Useful Post:
    immoneard (15th August, 2020), morrisgauge (14th August, 2020), rtbdiagnostic (14th August, 2020), sagie1zn (14th August, 2020)
