write me pm
i will help you
Hello few days ago i writed my ECU edc16c1 and i didint seen that but i loaded a wrong map file without HW only with SW so now i cannot read antyhing with my kess V2 like id, read map and i cannot write and recovery.
EDIT: i lost my hw id i try to read a id with kess v2 but it cannot connect to ecu,after i try to do it with k tag i solder pins to ecu, start ktag prograjm bdm mpc5xxx and now when ktag is try to ident ecu i gettin' this msg : picture. anyone have any idea how to solve it now ?
ecu # : dde7 793 539
hw 0281011411
write me pm
i will help you
anyone can help ?
Use BDM probe
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
your flex cable seems ok...
your soldering seems ok...
but this adapter between you use, where did you see that in manual...?
this adapter normally itīs used for delphi ecuīs based with mpc...
your ecu is dead, 12V and grd itīs not on the right position with this adapter between...
