what about exact original mileage?
Hello. Friends,
I need to correct the file I attach to 0 (zero) or 9 (nine). Is from a traffic.
ABS has no problem, still has 9km.
I already try but no lucky. Even once the hands stopped moving
If it is possible to activate the function that allows you to see the digits on the test stand, only with power .... If so, thank you.
A big thank you in advance
test and report back
opelbravo (14th August, 2020)
Hi.
At the moment has 25820...its right?
I will test it.
Hi.
Thanks for the file.
Is any way to see de information in the dash on the table?
Know the 12V(line 30) and Ground (line 31). This dash works with CAN, no line 15 used.
I already plug in the table, the hand motor move a litle and stop (like original). But (also) cant see nothing.
I wanted to see if the value was correct before plug in the car.
Hello jomberykaso.
A big thank you. You know what you're doing!
I already plug the dash and it's perfect. Default value of 4.
Thank you.
Your welcome.
