Results 1 to 1 of 1
    Jun 2013
    Kikinda Serbia
    Default Repair Steering column stalk - switch combination Megan II Laguna II ('03.-'10.)
    A very common problem with this part of the car is tearing the flat cable. Then an error occurs for the airbeg steering wheel .... What happens that such a malfunction is normal after ten years of car operation? With regular use, the plastic wears out when turning the steering wheel. Then there is a gap between the gears, certain parts are locked and the flat cable is broken. If that gap is not repaired, the flat cable is replaced, it breaks again in a couple of days.
    The method of reparation is shown in the video, not in English, where the entire repair procedure can be seen.
    https://www.youtube.com/watch?v=rOXMnlQeC5c
  2. The Following User Says Thank You to RadovanPetkovic For This Useful Post:
    jarek88 (17th August, 2020)
