Results 1 to 15 of 17
    Feb 2011
    North of Bronx
    Default 2009 Subaru Tribeca
    Hi DK,
    Posting a request for a good 2009 Tribeca dump (93c66 chip). Dump must be 2008 - 2011 year and in kms, but miles ok too (earlier dump dont work). Mileage doesn't matter.. Orig dump is corrupt... car doesnt start..
    Thanks in advance!
    A
    Sep 2018
    USA
    Quote Originally Posted by angelo44 View Post
    Hi DK,
    Posting a request for a good 2009 Tribeca dump (93c66 chip). Dump must be 2009 year and in kms (earlier dump dont work). Mileage doesn't matter.. Orig dump is corrupt... car doesnt start..
    Thanks in advance!
    A
    Another dump even if it’s good, I don’t think will fix your problem of car not starting. Some important information in original dump to make car start. Try posting your orig. file even if it’s corrupt. Maybe someone can fix it or pull the immo info from it.
  3. The Following User Says Thank You to MileageAudit5 For This Useful Post:
    angelo44 (15th August, 2020)
    Sep 2018
    USA
    Quote Originally Posted by MileageAudit5 View Post
    Another dump even if it’s good, I don’t think will fix your problem of car not starting. Some important information in original dump to make car start. Try posting your orig. file even if it’s corrupt. Maybe someone can fix it or pull the immo info from it. Also, you removed chip from board to write correct?
    Feb 2011
    North of Bronx
    This is the orig dump... in case it helps....
    So with this dump - no lights on dash at all (only check engine, brake, abs), car turns but dont start...
    With a good dump, I think lights should be back, see mileage, etc. but car dont start either.. But then can be programme the keys again...
    Thanks,
    A
    Feb 2011
    North of Bronx
    Bumping up.... Just in case anyone has a 2008 - 2011 Subaru Tribeca file for this cluster...
    Thx
    A
    Sep 2018
    USA
    Try removing the chip writing the original corrupt file back then reinsert into car. Might have to try couple old files because you probably tried reading/writing many times and have many backup files. One should work.
    Feb 2011
    North of Bronx
    I read chip in-circuit or removed. Same thing. Unfortunately, first time read was done with DSP tool and was incorrect... so my backup is incorrect...
    If you have a 2008-2011 dump would b much appreciated.
    Thanks!
    i have 2008 one in km.but you have to synch dash-immo-ecm with avdi or autel im508/608. check if your dash come alive first.
  10. The Following User Says Thank You to cklair For This Useful Post:
    angelo44 (19th August, 2020)
  11. #9
    Feb 2011
    North of Bronx
    thanks everyone for the help so far.... but I think I need a 2009... So far 2006 and 2008 don't work.... nothing lighs up except a few chec en=gine light, abs, etc.
    maybe it needs a CAN signal?
  12. #10
    clusters's Avatar
    Mar 2015
    Canada
    Or maybe it's a communication issue with the car?
  13. The Following User Says Thank You to clusters For This Useful Post:
    angelo44 (22nd August, 2020)
  14. #11
    Feb 2011
    North of Bronx
    So after adjustment cluster went completely dead... car turns, doesn't start, imobilizer light is ON. Not sure what comunication issue can be... This is a Subaru... if it was a VW or BMW... diff story...
    Or maybe its common for this car??
    Thanks in advance for any help...
    A
  15. #12
    Feb 2011
    North of Bronx
    Another bump..... just in case anyone has a 2009-up bin for this dash.....
    Thanks in advance.
    A
  16. #13
    Sep 2018
    USA
    I can get one from this website, it costs $10 exact price. Do you want the link?
  17. #14
    Sep 2018
    USA
    Thanks in advance.
    A
    I purchased this dump for you, will arrive in a few hours when they wake up. Don’t worry I cover payment. Thanks will send when arrives
  18. #15
    Feb 2011
    North of Bronx
    Send link please... let me see... thx.
