Opel does not have a procedure to turn off "Transport Mode"
Hello.
Anybody knows how i can turn off "transport Mode" in my car??
I try any combination and nothing... Still i can't diasable "Transport Mode" in whife car.
On dash blink batery and don't work Navi and diffrent module.
I watch on YT how disable on Astra J but with my car doesn't work.
THANKS A LOT for HELP.
budata (8th February, 2022)
Realy...?? but car is in TRANSPORT MODE and half electronic parts dosen't work in car... On Dash i have "TRANSPORT MODE ON" and i don't know how i can turn off this. I plug many computers and in BCM, IC, and diffrent components dosen't have function turn off TRANSPORT MODE.
1. You find a file for BCM without "Transport Mode", you change the VIN. 2. Record in BCM. 3. SPS with Global TIS. 4. Learning immo and key. I had the same problem.
I buy second bcm and i tried... maybe this one can i do something with this problem. i report... br
You need to change the VIN of the second hand BCM. It will not work properly. Radio SAFE ....
i still i search new file from bcm with transport mode off...
Hi guys I have same problem , any one find solution for transport mode? I got 2nd hand bcm without tranpprt mode but cant change vin.
I did sps programming but still old vin.
I can rewrite vin and all immo data, keys ....
,,Transport Mode:
To turn the Transport Mode On/Off, it will be necessary
to start the vehicle, activate the hazard flashers, press
the brake pedal (automatic transmission) or clutch
pedal (manual transmission) then press and hold the
Start/Stop button or turn the ignition key to the crank
position for 15 seconds. (The engine will turn OFF on
push button vehicles.) The same steps are used to turn
on the feature."
IMMODATA ACDelco EXX<=>BCM / DTC off + CRC ... Opel Delco HSFI 2.X , HSFI-C , MT35E
budata (9th February, 2022)
