At full throttle how much is injected quantity.
hello, can anyone see why the boost is up to 2040 mbar shows vcds boost specification.
I will add that the engine was set up complete awx passat 130pd and the electronics were left with the engine bxe 105pd.
map boost, boost limiter and svbl by change map sensor change to 3bar but still only 2040mbar.I personally changed the sensor to 3 bars and increased the svbl limiter. rest is changed by the tuner. Previous owner was doing a remap.
PRESS THANKS AND REPUTATION BUTTON IF I AM HELPFUL.
dzban (15th August, 2020)
Tuner forgot to change few turbo maps look at 18F494 18F60C change them and you see your 1,55Mbar np for help
File service only for diesel cars
STAGE 1, 2 EGR Off DPF Off FLAPS Off
Only manual solutions!
SKYPE: Leak_Rsc
Yes, you are right.
