kareszka (19th January, 2021)
Guys...problem with add card to Laguna III solved....
Im Idiot of the 01.2021r....
Im try add card by Laguna III menu...
car is Megane III - 1min job, all work
Sorry for my bad
godfathertre (21st January, 2021), TERMINATOR1000 (20th January, 2021)
If you are using a laptop
With small screen this can
Happen I always go trough the menu and make sure I have the right model selected you got there at the end.
Anyone tried this tool for Smart 453 key program from 2017?
Not support yet.
auto techniek (4th February, 2021)
I talked to him few day ago. Its in procces. But solution without bug takes time. Quarantine affects all.
Catalizator (4th February, 2021), p1et (4th February, 2021)
After Lonsdor in 2018 TDB1000 in 2019 Obdstar in 2018 Autel in 2019 .... & Free for AVDI users , it's not to late in 2021 ?
No need to waiting anymore it' s an ABRITES freeware since couple of months !!! R.E.T = R.I.P
I bought it for "free Protag +free Fiat Transponder" promo , 799 € and finally all Renault is included RR012 !!!!!!!!!!!!!!!!!!!!!!! FOR FREE !!!!!!!!!!!!!!!!
Terminator1000 please stop spam RET topic. Abritus wont cheat even customers for free + additional go online and charge Ams. Uco is online too and charge yearly subscription + will extra money for each option. Ret isnt perfect but have free updates and isnt overpriced.
castin (8th February, 2021), Catalizator (4th February, 2021), no__name (23rd August, 2021)
what ???? rr012 is free & no need internet , rr012 was made in 2016 .... I just inform dreamers ! NO AMS FOR RR012 NO AMS FOR ProTag ....
If you wan use R.E.T for AKL Clio 4 you need AES programmer , i use AVDI + ProTag ( 799€ ) for this , it's not my fault is Trafic 3 Twingo 3 Smart is FREE , it' not an spam , it's reality NOT SPAM : i use ABRITE to made dealer key
As you know, PINCODE read procedure by diagnostic is restricted for 2015+ Clio
IV / Captur vehicles. It's easy to override PINCODE read restriction when one
valid card is available, but key learning gets more complicated when all cards
were lost: HFM module must to be removed from the car, wires to be soldered
directly to NEC MCU to upload Data Flash content.
This article will describe step-by-step key learning procedure when all cards
were lost without intervention to the HFM module. All you need is a blank card
(of correct type) and transponder programmer, capable to operate with HitagAES keys. Current article refers to Master Key III (MK3) transponder (me i use ProTag )
programmer, but you are free to use any other programmer with support for
Hitag-AES transponders.
Before to proceed please check if you got latest software of Renault ECU Tool
downloaded (V2.93 or higher).
REPAIR ECM MILEAGE: EDC17, DCM3.4, SID305/306/307/309/310, EMS31XX (OBD-II CAN-BUS)
Reset total distance in ECM.
I have tried this, on 2 different Masters, sid310 ecus.
Failed.
Any off you guys tested this?
AKL hfm, i just read these modules with a prog.
And buying protag, that i would never do.
It must me possible to alter aes key data with Xhorse tools.
I get comm, but no result.
Tried a few methods, with battery supply.
Turning , and leaving ignition off, various times. etc
does anyone know if the project is working or is it the end and this is the latest update?
