Virgin HFM captur, after I try to program cards, autel im608, 1 of the car and 1 blank, reprogram the HFM with the Renault ecu tool or just in renault?
Can someone explain to me how to proceed with the renault ecu tool to get HFM active? Thanks
Do all by instruction, software write all steps
Renault Ecu tools?
Yes, you need isk, and you can learn HFM with renault tool
Virgin HFM, without one active card or no ISK? I think not possible with RET. If You hawe one working card, then OK. Virgin HFM, insert WORKING card, then read PIN and learn new card.
I think im608 somethere saving isk, need try relearn HFM with im608
Virgin HFM!
Possible R E T:
1 car card with data, even if the car given to virgin HFM does not work
Anyone tested any of the new updates I tought we where getting some more vehicles but very little on 2.99
godfathertre (14th April, 2021)
why does everyone need to program keys ..... besides these functions there are tons of other functions that can be added to this wonderful device. everything takes time, we expect and get
That is true but key programming gives usually good starting point for replacing damaged control modules. And keys are common place that break even with new cars. At least nice to have backup solution if damaged key repair fails.
But yes, at least for me Laguna II card reset pops up question: Why?
Edit: I think that some Renault generic TPMS feature could be nice. All information should be available and should not take too much effort to add... At least more use than card reset.
rellullapaasee (14th April, 2021)
Renault ecu tools, already programming clio iv and captur without problems (either before or after 2015). Without being AKL!
