Results 1 to 7 of 7
    fudballer's Avatar
    Aug 2019
    Serbia
    Default Audi PopCorn Limiter
    Hi, can someone please make Popcorn limiter in my map. Car is Audi A4 B6 2003 1.9 96kw EDC15P+ FP AWX
    Jul 2018
    poland
    Map location - 00x741A2 (16/255 LoHi)
    Your file SVRL - 4800
  3. The Following User Says Thank You to socha1997 For This Useful Post:
    fudballer (15th August, 2020)
    Jun 2020
    Quote Originally Posted by fudballer View Post
    In diesel engines it is not correct to speak of popcorn, the effect of popcorn is only in petrol engines.
    As indicated by the user above me, you can change the SVRL which is the single value that tells the engine at what rpm it has to cut the injection.
    The effect is different not comparable to the petrol engine.
  6. The Following User Says Thank You to ecuprogramer For This Useful Post:
    RBTuning (19th August, 2020)
  7. #5
    fudballer's Avatar
    Aug 2019
    Serbia
    Socha1997 Thank's a lot for tuning my map im really thankfull. Krisfuzzy so you wanna say like this is not popcorn limiter it's something a like popcorn limiter?
  8. #6
    fudballer's Avatar
    Aug 2019
    Serbia
    Ecuprogramer Thank you soo much man i will make video and send you. Thanks again friend
  9. #7
    Jun 2020
    I just want to say that in the diesel engine even cutting the fuel will never have the popcorn effect that you have in petrol.
    So it is correct to speak of hard cut no pop corn effect
