    Jan 2014
    Piaseczno - POLAND
    Default OPEL GRANDLAND X wiring diagrams needed
    HI. I need wiring diagrams of BSI, BSM and ECU.
    If must to pay, then I pay.
    Car do not have a ignition status, no power on OBD, no diagnostic.
    Remote in key working fine. Car reacting for key.
    VIN:
    W0VZRHNY0JS039502
    If I helped, please click button "thanks".
    It does not cost you anything.
    Apr 2011
    South East UK
    What year and engine is this ?
    Jan 2014
    Piaseczno - POLAND
    2018 1.2T 96KW
    rob h's Avatar
    May 2011
    Same as 3008 Peugeot.
    Delphi bsi in place.
    If opel support fails.
    Grab a vin, from a 3008.
    Make sure, to choose keyless, OR non keyless.
    Is it C3 Aircross. Engine HNY. Valeo V 46 or VD 46,You need PSA Diagbox ,I m not sure. You need Diag and know how,study.
    Jan 2014
    Piaseczno - POLAND
    Problem solved in second day in workshop. Some stupid guy swapped two black connectors. The first connector is connected to the BSI, the second to the cable near the steering column. The connectors are interchangeable. Luckely nothings burned! Such things only in PSA: D
  7. The Following User Says Thank You to jarek88 For This Useful Post:
    donzzzz (25th December, 2022)
