Results 1 to 2 of 2
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Default 2012 Buick Lacrosse Ecu programming issue
    Hey all!
    Im attempting to replace an ecu on a 2012 Buick lacrosse. I have a used one trying to program with SPS.
    I select replace and reprogram, it goes through, communicates with car and begins the flash. At 99% i get an error and after that every time i attempt to re start the programming i get E6787 cant reprogram the same calibration. The Vin remains the one from used ecu even though i input the correct one i need.
    I have found a few threads with no solution. Any help with this would be greatly appreciated!
    Thanks!
    alex_r_2001's Avatar
    New Jersey ,, USA
    Check on acdelcotds website to see if its Global A Architecture.. If it is then it will not work because of environment security and pin code.... Must put New Pcm if indeed its global a
    This vehicle is Global A I checked
  3. The Following User Says Thank You to alex_r_2001 For This Useful Post:
    ateyourv8 (23rd August, 2020)
