Results 1 to 3 of 3
    Dec 2018
    Ireland
    Default VW EDC16 Popcorn Limiter
    Hello, Currently running a stage one file for a B6 VW Passat on EDC16. I was looking to get a popcorn/hardcut limiter added via the single value rev limiter at about 4200rpm, currently not touched so probably at factory value of 5300rpm.
    Currently do not have access to modify the file and correct for the checksum. I don't mind paying for the change.
    All the best, Michael
    Jul 2018
    poland
    Quote Originally Posted by Ford5030 View Post
    Your file.............
  3. The Following User Says Thank You to socha1997 For This Useful Post:
    Ford5030 (23rd August, 2020)
    May 2020
    tot557545@gmail.com
    Ford5030
    Hi everyone you need to know something 4200rp hurdcut will be a small voice, I will make you hurdcut at 4700rpm and test it will be better ... but of course first test the solution from a colleague and then mine and make a video of the solution from kelege and send it to me and then when you try mine solution also make a video and send it to me.thanks
